Mix Mx licenses in one organize.
Narinthorn
I read in your document. said that they cannot mix licenses in the same organization. I came to check in my organization. It was found that there was a mix of licenses. So, I'm wondering if this will be a problem. And if I want to buy new MX, what kind of licenses do I need to purchase?
5 Replies 5
Brash
What is your current MX Product Edition in Organization -> License Info?
Do you know if the licensing in your organisation has been upgraded or downgraded via Meraki Support?
Where did you read this? It doesn't make any sense.
https://documentation.meraki.com/General_Administration/Licensing/Meraki_Per-Device_Licensing_Overvi...
I remember  meraki was talking about making mixing possible in the future. It seems like its already possible(for pdl).. maybe verify @ support.
I have never heard about that, I have organizations mixing MX and Meraki has never advised us about it. It does not make any sense to me.
Ryan_Miles
What was the most recent MX license you added? Once you have any Adv Sec or SDWAN licenses it should not allow adding any further Ent licenses as the Org has been moved up past that level.
Ryan / Meraki SE
If you found this post helpful, please give it Kudos. If my answer solved your problem click Accept as Solution so others can benefit from it.
