Hopefully I am doing something daft however on my MX at home which has a advanced security license I don't get any menu options for content filter or threat protection. Below is a screenshot of the options I have available. The device is a MX68CW
Solved! Go to solution.
Are you using co-termination, and does the licence screen say you are using "Advanced Security"?
That's a bit weird.
I've got an MX68CW with Advanced Sec licensing and definitely see the content filtering and threat protection in the list.
Can you manually navigate to the URL?
https://<shard>.meraki.com/<stuff here>/manage/configure/security_filtering?from=security_sd_wan
Same here. Strange thing 🤔
Odd.
I have it on my MX68W with adv.sec.
Well this is embarrassing....
Turns out I was looking at the wrong line in my licensing page. It HAD advanced security but was renewed with Enterprise.
My bad sorry for wasting everyones time!
At least it's not like you caused an outage for 8.5 million computers with it though 😂
Given it's my home router it's not a big deal. But in regards to outages I'm starting small and will work my way up to a global outage.
It's a good time to buy Crowdstrike shares though 😎
