MX appliance 1: Main subnet 10.0.1.0/24, VPN Subnet with address translation 10.0.91.0/24
MX appliance 2: Main subnet 10.0.1.0/24, VPN Subnet with address translation 10.0.92.0/24
MX appliance 1 and 2 are participants in a Site to Site Meraki VPN. The main subnet of both MX appliances is the same so address translation is used for the VPN Subnet.
The question:
Due to a device configuration limitation, a local device on MX appliance 2 (IP 10.0.1.10) is programmed to communicate with another local device on that MX appliance using the VPN translated address (IP 10.0.92.11). The Local IP address of the second device is actually 10.0.1.11.
How does the MX handle this situation? Does the MX translate back to the local device within the same MX or is the address translation only meaningful for communications across the site to site VPN?
