Migrating to new hardware
Raffi
We're replacing an MX67 with an MX75 to get better throughput. We want to keep the configuration the same. Is there a process to do this?
2 Replies 2
Inderdeep
KarstenI
Yes, just replace it. The config "lives" in the cloud and gets pushed to the new device when you remove the old one and add the new one.
You only have to adjust the VLAN-to-port mapping and re-enable AutoVPN.
