Meraki subnets outside of the Auto-VPN
househed
Can non VPN subnets, eg a guest VLAN, overlap across multiple MX appliances?
Say I have 3-4 sites that have a guest VLAN that is not in the VPN, use the same subnet.
I dont see why not, as I already a few like that, but thought I'd ask if there are any issues/limitations.
Thanks.
GIdenJoe
Yes you can overlap those subnets but you will not be able to include them in auto VPN.
The sanity check dashboard does is to see if that subnet would appear in the routing table of another AutoVPN participant.
You could notice if you clone a network it does have the same networks but the site-2-site feature is disabled then to avoid this scenario.
2 Replies 2
GIdenJoe
Abel85
You can also enable Site-to-site VPN Translation (VPN NAT) if you want to add them in the future:
https://documentation.meraki.com/MX/Site-to-site_VPN/Using_Site-to-site_VPN_Translation
