Client VPN on Z3C
mrjelly
Client VPN on Z3C
I would like to setup an Anyconnect client VPN service and have a Z3C and an MX95.
Is it possible to setup a client VPN service using the Z3C and are there any limits on the options when compared to the MX95?
The imitation is actually the issue of the number of clients ,supported on the Z3 compared to the MX.
The Z3 is recommended for a maximum of 5 devices, including the VPN client.
You can enable it without any problem.
You can test it before put it in production.
mrjelly
I don't fully follow, sorry. Are there any differences in the capability of the Z3C and the MX95 when using it for a client VPN service?
Thank you
