Hi all,
I have a question regarding client vpn of meraki. If i use private ip address (FTTH) for WAN link, can i use client vpn service with that WAN ip?
Thanks much!
Solved! Go to solution.
no problem @JJM - hope that makes sense?
Just think, if you're outside your firewall/MX (at another site etc) can you ping/reach the IP of the device you want to VPN to? If you can't then the client VPN won't be able to connect to it.
All the best
Hi @JJM , the MX WAN IP/Hostname needs to be accessible via the internet so I would say the answer is no
Thank you, DarrenOc.
All the best
Maybe set up some NAT / PAT on the firewall that sits between the MX and the Internet, so that you initiate the tunnels from your clients to a public address that lives in the firewall, but which the firewall then translates to reach the private address on the MX.
??? Eh?? I can’t picture that one.
No public ip, i just get DHCP address from ISP which get access internet.
