Meraki client vpn with private ip adrress
JJM
Hi all,
I have a question regarding client vpn of meraki. If i use private ip address (FTTH) for WAN link, can i use client vpn service with that WAN ip?
Thanks much!
DarrenOC
no problem @JJM  - hope that makes sense?
Just think, if you're outside your firewall/MX (at another site etc) can you ping/reach the IP of the device you want to VPN to?  If you can't then the client VPN won't be able to connect to it.
All the best
7 Replies 7
DarrenOC
Hi @JJM , the MX WAN IP/Hostname needs to be accessible via the internet so I would say the answer is no
JJM
Thank you, DarrenOc.
DarrenOC
All the best
GreenMan
Maybe set up some NAT / PAT on the firewall that sits between the MX and the Internet, so that you initiate the tunnels from your clients to a public address that lives in the firewall, but which the firewall then translates to reach the private address on the MX.
DarrenOC
??? Eh??  I can’t picture that one.
@JJM you have a modem/router that has the public ip from your ISP?
JJM
No public ip, i just get DHCP address from ISP which get access internet.
