In a HUB and SPOKE design, where the HUB is configured with 2 MX'es, Routed MX is connected to the Internet and does firewall/nat.
The second MX OAC is connected to the LAN port of the MX, doesn't matter what port. What matters is that they function together as a Layer 2 Bridge, oac being the VPN Concentrator.
The OAC has a public ip on the physical port of 11.11.11.11 and both routed and oac device share the same public ip address 22.22.22.22.
There are also 2 port forwarding rules for udp and tcp having the same Public/Local ports(43060) that are configured on the Routed MX towards the physical ip address of the OAC 11.11.11.11, so if nat occurs, the port should not change dynamically.
Whatever comes from the LAN HUB to the Routed MX, or local breakout, it will be natted.
Whatever comes from the Internet and is not destined to the OAC, it will be natted.
As we know, the AutoVPN traffic, first arrives at the Routed MX and after it will be sent to oac for decryption and vice versa
Is the routed mx in the HUB doing NAT when it receives the encrypted traffic from the spoke devices before sending it through the OAC device? Or it will just simply forward the encrypted traffic without doing NAT in my case?
1.Why yes? Walk me through the process
2.Why not? Walk me through the process
Is the routed mx doing NAT when it receives encrypted AutoVPN traffic from the OAC before sending it to the spokes? Or it will just simply forward the the encrypted traffic to the spokes without doing NAT in my case?
