- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
CLIENT VPN not working.
Good day Community,
I need help with something.
Here is my design:
Now I am trying to get a vpn connection from the internet to the Client VPN however I am not seeing any of this traffic. I setup port forwarding but still cant see anything.
Can someone please help me out!
Solved! Go to solution.
- Labels:
Client VPN
Firewall
Other
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The only thing I can suggest is that you do the troubleshooting.
Check the error code on the client system.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Upstream NAT/Firewall Issue on the MX
If your MX is behind a NAT device (for example, an upstream router or ISP modem), the MX uplink IP might have a private IP in the 172.16.X.X or 192.168.X.X or 10.X.X.X subnet range. Ensure UDP traffic on ports 500 and 4500 is being forwarded to the private uplink IP address of the MX.
Unable to Connect to Client VPN from All Devices - Cisco Meraki
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Alemabrahao,
Yes the 2MX CLUSTERS is behind a upstream router.
Now I have configured the following on the cisco router before posting on here for support:
ip nat inside source static udp X.X.99.66 (PRIVATE IP OF MX) 500 (PUBLIC IP) extendable
ip nat inside source static udp X.X.99.66 (PRIVATE IP OF MX) 4500 (PUBLIC IP) 4500 extendable
ip nat inside source static tcp X.X.99.66 (PRIVATE IP OF MX) 1701 (PUBLIC IP) 1701 extendable
But still it seems not to work?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Do you test from the internet side. Or from a client on the lan side of that mx
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi there ww,
I am at home and trying to make a vpn connection from my laptop to the the Client VPN that I configured on the MX cluster.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Are there any ACLs on the routers which might not be allowing the traffic?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This was a issue with my windows laptop and not with the VPN. I had to add a registry entry to my laptop for this to work! I am glad that is now working.
https://www.systweak.com/blogs/fix-vpn-809-error-on-windows/
