Meraki MX84 - Multiple WANs plus DMS | How do I convert LAN port to Routed Interface?
CJR_ZA
Project is a SonicWall to Meraki firewall migration. I've noticed that the Meraki MX only allows by default 2 x WAN interfaces and that the LAN ports do not have options to convert to routed interfaces that can have ip addresses. How can I migrate 5 x WAN links plus a DMZ onto the MX84?
2 Replies 2
Dont use meraki if you want 5 wan links on 1 device
@CJR_ZA if you want more than two WANs then you need to use the make a wish feature in the dashboard, there is a button labelled as such at the bottom of the screen.
To create the DMZ enable VLANs on the MX and then create a second VLAN with an interface IP and apply it to a port.  You can then create separate rules between the LAN, WAN and DMZ
