Hi Team,
MX84 reflects error of "Bad IP assignment configuration" through Broadband link configuration as WAN. Please suggest for fixation of issue.
Thanks,
Niraj
hi @Niraj , has the error cleared or is this still remaining? Have you verified your iP details of the wan port with your ISP? Is there an iP conflict and are your dns settings correct?
Some troubleshooting tips below:
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Bad_IP_Assignment_Con...
The troubleshooting link does not work.
Which I presume is the same link in the dashboard, which does not work either.
Hi @Niraj!
We've noted this with the relevant UI teams as a to-do, and the request is in the upcoming work queue to change it to the correct link. Once complete, the link should re-direct you to the correct location, being https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Network_Alerts_and_No...
