- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Meraki MX64 - Static Routing
Hi
I am new to Meraki equipment and this forum, I am also not exactly an experienced network administrator but I have worked on routers and switches before, we replaced a Mikrotik Cloud Core router with this new MX64 for VPN reasons
So the issue we are having is to add a new subnet to the MX64, our main DHCP subnet is 192168.2.0/24 and we have devices with static 192.168.5.xxx IPS as well, before on the Mikrotik it was simple to just add another subnet to a port or ports and all was good, no VLAN, etc was needed
How do I do this on the MX64 ?
Thanks a bunch in advance for any help!
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
you have to create a vlan for that.
After the VLAN creation you can assign one or more ports to that vlan.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks for the reply
I should have mentioned that DHCP for 2.xxx is handled by our server and on the MX64 there is no DHCP at all
So I activated VLAN and added the new VLAN ID 10 as subnet 192.168.5.0/24 and MX IP as 192.168.5.1, I made sure both my default VLAN 1 and the new ID 10 are both allowed on all ports, I have no luck to ping a 5.xxx client from a 2.xxx client, what am I missing ?
By the way I have no static route added anymore, do I still need to add one ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Where are the clients connected and what vlan is on the access port and on the trunk port connected to the mx?
What ip and gateway has client 1 and ips1 ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Please excuse my ignorance, but I am willing to learn
We have 2 other switches where the clients are all connected too, none of those switches have a VLAN setup, port 1 on the MX goes to one of the switches and from that switch, it goes to the next, some of those switch ports go to antennas which go to remote locations, 7 to be exact so there are more switches downstream
On the 5.xxx clients, we have for example 192.168.5.100 netmask 255.255.255.0 and gateway 192.168.5.1
I assume I am missing something major here, we had it working by making a static route to the old Mikrotik router which we reset and gave one port a 2.xxx IP and set a 5.xxx subnet on another port and plugged that back into one of the switches, but this just doesn't seem right and we had issues with VoIP equipment on 5.xxx
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It looks like your mikrotik supports more then 1 IP on the interface/default vlan.
Meraki only support 1 IP/subnet for each vlan interface. So you need to (re)design your network based on vlans
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ww,
That's what I was afraid I would hear, VLANs are the only option.
That does bring me to another question, as mentioned we got this new MX64 router only because of a VPN issue between the Mikrotik site to site VPN to another MX64 router at another location, I keep seeing the passthrough or VPN concentrator option on the MX, I have read a bit on this but fail to fully comprehend what I can do with that
Could I have kept the Mikrotik router in place and disabled the IPSec VPN and just added the MX and use it only for VPN ?
If so could someone explain how I would connect this to our current router/network to accomplish this?
Thanks so much for any help!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
We have the WAN port on the MX uplinking to a different brand gateway's LAN port, using a unique LAN subnet, not a VLAN. The other gateway is connected to the internet using PPPoE via a Vigor 130 modem in bridge mode (for IPTV reasons).
The other gateway is configured as a DHCP server and the MX receives its IP from the DHCP server. I have successfully tested running a VPN from a Z3C using LTE to the MX.
We have not needed to address the Double NAT issue, which simplifies configuration of the upstream gateway.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks for the feedback
We are going to try it in VPN concentrator mode see if we have any luck
If I need more help with this I will start another discussion
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
If numerous VLANs are used, I have found it simpler if there is a direct correlation between the VLAN ID and the IP address. For example
VLAN | VLAN ID |
192.168.11.0/24 | 11 |
192.168.111.0/24 | 111 |
192.168.121.0/24 | 121 |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
That sounds like sound advice, thanks
At this point it looks like I will need to redo my network
