Nice @PhilipDAth !! Being an ex-AWS employee I loved your solution! Nothing better than a full armour against DDoS and other attacks. Combining WAF and a Load Balancer or CloudFront and WAF is a powerfull solution.
Migrating the Web App to cloud and protecting it with cloud-native solutions (first choice) would keep your MX firewall mostly out of the hacker's scope. I.e.: allow-list and/or Layer-7 country deny rule filter the attacks BUT the MX would still have to deal with discarding the packets. Therefore, in a DDoS situation MX might slow down or even stop due to high CPU usage.
However, the downside is cost increase plus the time to migrate the web app to cloud.
Second and third choices are great as they don't require migrating the web app to cloud. But still, this is kind of an overkill from a cost perspective.
@alemabrahao solution would be my first choice but I understand most companies don't know the source IP. So the ideal (from a cost perspective) is just do Layer-7 country deny rules.
What I personally do is to google what are the top 10 attacking source countries and add those to my country deny list.
And of course, no solution comes without a downside / side-effect. In my case is the ones I already mentioned (MX would still be a target) but the problem is sometimes you end up blocking legit traffic. E.g.: some web pages might host part of the content on a denied country or maybe some of your web app clients do come from those countries.
If you get affected by those scenarios perhaps it's better to increase your budget and move your web app to the cloud and protect it with cloud native solutions.
