Meraki MX and Azure VPN gateway in a route-based mode
Synnapex
I know there were several topics about Azure-Meraki VPN tunnels...but here is another one.
I have a client with Azure VPN Gateway in route-based mode, and, as I understood so far, there is no "out-of-the-box" solution to establish a VPN tunnel to Meraki MX.
I'm wondering if Meraki Support will activate IKEv2, will I be able to connect to Azure VPN gateway configured in a  Route-base mode?
Is there any solution to this situation at all?
ChrisC83
I believe Meraki with IKEv2 will work with route-based GW on Azure.
You will need to upgrade your MX to firmware 15.x and call support to enable the IKEv2 on the specific tunnel.
ChrisC83
Synnapex
Thank you, ChrisC83,
We will try that and I will update the topic after.
Synnapex
Update: by enabling IKEv2, Azure routed VPN started to work
Jeizzen
As of may 2020, I was able to create a connected vpn with Azure that worked by configuring this way :
Azure : routed-based vpn IKEv1
Meraki : Azure preset, but deleting the MD5 in phase 2
