As I understand it, you have a FW cluster behind an MX cluster.
In that scenario, it seems that you need to connect both firewalls to both MX'es (MX cluster does not operate in Active-Active scenario for simple routing purposes), otherwise, if your primary FW will crash while the primary MX will still be up nothing - good will happen.
