Get DHCP from another server for a vlan
OBARRERA
Hi everyone!
I have a problem in a configuration with a external DHCP Server.
That server is in another network with the IP 192.168.143.X
In the VLAN I desable the DHCP service but I don't know how I can configurate the meraki so that VLAN catch the other DHCP.
I hope someone can help me 😞
5 REPLIES 5
Hi WW,
I already read that document, if I understand it well that only works if the server is in the same network but in other VLAN, isn't it?
My server is in a complete diferent network.
The server is reachable using (auto)vpn?
BlakeRichardson
@OBARRERA as long as the DHCP relay can acces both the subent and DHCP server there sohould be an issue. If the relay cannot access the DHCP server because of the way the network is configured you need to take another approach.
GIdenJoe
Yep, if your MX is serving a VLAN it can play relay server, so you just configure DHCP as relay towards another IP.
You only have to be sure your MX has a route to the subnet where the DHCP server is at and that the DHCP server subnet has a route to the VLAN the MX is gateway of.
