Hi Everyone,
Looking for help please. I Need to connect to a supplier from my Cisco ASA5515 and they are running a Meraki MX64 via an IPSEC VPN
Their local LAN clashes with one of my networks so I am asking them to
NAT their 192.168.0.1 to 10.30.40.xxx network
and create a VPN tunnel between with protected traffic of 10.30.40.xxx to 10.30.50.xxx
They will only need 6-8 devices so could do static 1:1 NAT
However they are telling me that the Meraki MX 64 will not handle this, please can you advise if this is the case?
Maybe they are just mis-understanding me.
TIA
Mick
Solved! Go to Solution.
Meraki does not support VPN NAT on tunnels like that, no.
Thank you.
Hi
Is this just the MX64 that does not do it? Is there a model that will do what I am looking for?
Regards
Mick
That's not specific for particular models.
@Mick_R wrote:
Thank you for answering, do you mean no Meraki will do what I need?
That is correct. No Meraki firewall will do VPN NAT on a standard IPSEC tunnel. ('Third party tunnels' in Meraki slang.)
Thank you everyone.
The customer has now bought a Cisco ASA 5506
