Meraki Cloud Connectivity Notice Email
rhinkamper
I received the following email, but when trying to configure the inbound rules for SNMP Traps it will only accept an IPV6 CIDR address for the source and destination but the info from Cisco I have is only for the IPV4 addresses.
BlakeRichardson
I think you need to add the rule further down the page under port forwarding. You are trying to add a rule under the IPv6 section. The silly thing is the ability to add IPv6 rules still shows even if you have IPv6 disabled...
www.btr.net.nz
2 REPLIES 2
BlakeRichardson
www.btr.net.nz
Yeah I have IPv6 disabled, which was confusing. Thank you!
