Meraki 1:1 NAT Inbound NAT Port Range Not Working
MarkCruz
Just browsing
I configured an inbound 1:1 NAT with a port range that is not working.  The single port entries such as port 80 and 443 are working but the range is not.  Is the syntax separated with a dash correct?
2 Replies 2
KarstenI
Yes, the syntax is correct:
https://documentation.meraki.com/MX/NAT_and_Port_Forwarding/Port_Forwarding_and_NAT_Rules_on_the_MX
Have you done a capture on the WAN-port to see if the packets are really coming?
Thank you for the documentation post and verifying syntax.  I proved that the NAT is working with a packet capture on the public side of the firewall and a server side Wireshark capture.  Traffic ic making it to the server through the firewall.  I do not believe the server application on port 9000 is listening so I'm working with the app developer on that.
Thank you so much for your help!!
