Solved! Go to Solution.
Would a syslog server not suffice to capture all events
Hi @FrancescoTCS90 ,
not something I’ve ever needed to do but is it worth a call into support to see if they can amend the value for the network/Org in question?
Hi @DarrenOC
I agree with @DarrenOC - if you are wanting persistent event logging you should be looking at syslog.
Otherwise, as @jdsilva says, the API is the best way to accomplish this.
https://developer.cisco.com/meraki/api-v1/#!get-network-events
Thanks to all,
I will propose to the client the configuration of a syslog server.
Greetings
