My first Meraki system was installed a couple of weeks ago (love it) but I am still figuring things out.
The Need:
I have all Axis cameras but one of them, which is pointed at my aquarium, needs to be viewable by my "fish guy"
Is there a safe & easy way to him to view my Axis camera from outside the LAN?
Solved! Go to solution.
Note that unpatched security cameras are the #1 source of IoT based compromises. Make sure you patch your camera firmware before starting.
As others have said, you could configure a port forward.
https://documentation.meraki.com/MX/NAT_and_Port_Forwarding/Port_Forwarding_and_NAT_Rules_on_the_MX
A more secure method would be to use client VPN.
https://documentation.meraki.com/MX/Client_VPN/Client_VPN_Overview
Wyze cam. If you want simple. (Non Meraki) Give it a search.
you'd need to open the port the stream/camera uses on your firewall - eg port forwarding
On the dangers of IoT and fish front.
If you can, I'd put those cameras on a separate subnet with some firewall rules, in addition to patching the heck out of em.
