Maintenance mode
SteveDW
Maintenance mode
Hello, is there a way to place an entire Meraki network in maintenance mode so that it can go offline while under development? I am adding a number of new networks and devices (claiming). While configuring the networks, they would enter a maintenance mode (offline) similar to VMware. Any insight is appreciated. Thank you.
In other words, there is no such function.
No, It's not necessary.
SteveDW
Thank you alemabrahao! I appreciate your quick response.
If you prepared to use the API you can use "Action Batches".  This lets you group a set of changes together, and either all of them happen or none of them happen.
https://meraki.cisco.com/blog/2019/06/action-batches-a-recipe-for-success/
