MX and OT Protocols
INTERNAL-MX
Just browsing
MX and OT Protocols
Hi Team, I hope you are well.
Please your comments in the following question:  Is there any reference about the applications and protocols supported by MX ?   I would like to know if the MX is able to detect and filter industrial protocols (OT).  Any links with protocol list or application list ?
Thx in advance
Guillermo.
2 Replies 2
Brash
The MX (like any firewall) can pass all network traffic.
The MX uses NBAR for traffic/application classification. You can see a list of NBAR protocols at the link below.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/qos_nbar/prot_lib/config_library/nbar2-protocols/n...
If it is based on IP it will be able to pass it.  It probably won't be able to filter it unless it uses a specific TCP/UDP port.
