MX85 Uplinks
Eyad2411
MX85 Uplinks
Dear Team,
The MX85 has 4 dedicated WAN uplinks, 2 x 1GbE SFP ports and 2 x RJ45 1GbE ports.
My Question is, Can I implement the 4 WAN Links to be Active at the same time?
or it is going to be 2 uplinks as Active and 2 as Passive?
the same question is over MX75 in case of 3 Uplinks.
Thank You in Advance.
CptnCrnch
Unfortunately not, only 2 uplinks can be used
5 Replies 5
CptnCrnch
Inderdeep
@Eyad2411 : You can use only two from the 4 uplink ports
https://documentation.meraki.com/MX/MX_Installation_Guides/MX85_Series_Hardware_Installation_Guide
www.thenetworkdna.com
GIdenJoe
Indeed, WAN1 has two interfaces and WAN2 has two interfaces and you have to select which one to use for each WAN.
MilesMeraki
Not at this stage; I've been told in later firmware releases more than 2 active WAN links will be supported for SDWAN purposes.
GIdenJoe
While that would be awesome, I don't see that happening before any official announcement.
I.E. don't bet on it.
