HI
I have a three hub network on AUTOVPN. with spokes connected to all three hubs. The hubs act as gateways to existing MPLS network. I connect all three hubs via BGP to the local mpls routers.
I then set a default "internal route" that sends out to the spokes.
Trouble is one of the hubs MX85 HA seems to be sending out the learnt routes from the mpls and now all traffic goes via this link as has better matches.
I cannot find out any detail why this is doing it and not the others. the other hub sites are larger and mx250 devices HA.
this is causing all traffic route via the smaller hub rather than the larger ones
the work around i have used is to disconnect this hub from majority of the network.
