I have an MX84, two internet links (100Mbps each). WAN2 shows as Active, WAN1 as failed.
Both are configured with static IP addresses, and worked when tested with the same addresses from a laptop connected directly to the ISP.
What is strange, is that a traceroute from the MX will show the correct path when tested with each uplink. WAN1 (in failed state), will show the expected next hop and the ISPs internal hosts. Those will be different from WAN2.
Hourly tested is configured in SD-WAN, and both links show packet loss near 0% (WAN1 shows 100% until it was plugged in, of course)
The route table shows:
The configuration is below. Clearly, traffic can flow on that interface, but status will not change to Active, and I suspect this means it will not send client traffic through it (it is configured to load balance).
I've restarted already. Any ideas?
Thank you,
Pablo
