After a long disconnection, the MX doesn't reconnect itself to internet, i need to connect a pc directly to the ADSL modem, and reconnect the ethernet cable of the modem to the MX.
Any workaround ? In the dashboard.meraki.com i tried to resave the configuration with no luck. I didn't found a restart button also.
Thanks for your lights !
Ludovic
Are you running recent firmware?
What reason does the MX give on its local status page when it is disconnected like this?
Do you have a remote connection to the DSL modem to reboot it? We also use a USB aircard to our MXs so we can continue to manage them when the primary internet is down.
Are there any outgoing firewall rules on the DSL modem that could be stopping management traffic from the MX unit?
Yes, the MX is uptodate
No, there is no outgoing rules.
