I have a MX84 that the WAN port is coming up as 100/half. I dont have access to the WAN config from the providers equipment. I'm looking for somewhere to change or modify the port settings for the WAN ports but cant find anything. Can someone share some light on where to fix this? Is this possible?
If you are not on the local LAN you may need to go to the Network-wide>>General>>Device configuration to enable local status page access and set a password. Also may need to check Security>>>Firewall>>> Security appliance services and verify allowed remote IPs. Then access the MX from its public IP.
I see no "ethernet" option on the Appliance status page of the MX84. Where is this located? Under the Uplink tab there is no where I find to set the speed or duplex of the port. Only to set the IP info.
