MX84 17.10.4 Cannot Reach HTTP
meraki-newbie
Hi all,
I have some issue, that under my current MX84 that using MX 17.10.4 firmware coluldn't reach any http web domain.
It's confusing since i didn't apply any content filtering/firewall setting to http domain.
Could anyone share some thoughts? Did I need to upgrade to the  MX 18.107 ?
Thank you
5 Replies 5
Have you opened a support case?
meraki-newbie
yes, but didn't hear any answer yet
drgnslyr
There is a known bug that was resolved in 17.10.5 where this can happen if you have Web Cache enabled in the SD-WAN settings for your MX.
meraki-newbie
is that means, the higher version than 17.10.5, such as 18.10.6 or 18.10.7 will resolve it too ? or only will resolve on 17.10.5 ?
meraki-newbie
we have already disable web cache as TAC suggestion, but it didn't resolve
