MX68W and static routes
Hi there
I have a new MX68W and want to send rfc 1918 ip addresses to a MPLS interface.
Is it true that the MX68W only supports 2 static routes ?
Accepted Solutions
Re: MX68W and static routes
I think it works now, but sometimes i got some errors with many red lines..
But after some testing i got all static routes now....
4 REPLIES 4
I'm not aware of a limitation of 2 static routes. Where are you getting that information from?
Nolan Herring | nolanwifi.com
TwitterLinkedIn
@NolanHerring is correct.  Their is no practical limit on the number of static routes.
It has a limit of two WAN interfaces - which is perhaps where that number has come from.  But it sounds like your MPLS circuit will be connected via a LAN port anyway.
what if we have MX in concentrator mode and links are connected on WAN ports.
In this way, can we add multiple routes towards WAN interfaces ?
