MX68 LAN static route or default route.
dhayes89
MX64 Hub not using static route 0.0.0.0/0 to send all traffic from spoke to internal network. The spoke tracert tool for a public IP address 8.8.8.8 , the hub recieves the traffic vie the vpn tunnel but sends the traffic to its WAN interface instead of using the static route for the internal network.
 Spoke tracert
Only if you first select the default route at the hub. To participate  in vpn. Then the spokes learn that default route in the vpn
So if you select that static 0.0.0.0 route at the hub. Then set it, in vpn
8 REPLIES 8
Do you advertise the static default route at you hub into vpn?
If you do,
can you unselect the "Default route" checkbox at the spoke vpn settings.
dhayes89
No,the Spoke is using the HUB as default route.  The traffic makes it to the HUB.
So if you do select to select the  static default to use vpn and remove the checkbox it should work
dhayes89
Are you saying un-select the Default route for site to site VPN
Then advertise the static route on the VPN, instead of this.
dhayes89
Ok, will try that later today after the office is closed.
Thanks , that works.
HUB
dhayes89
Thanks. 😁
