Meraki Firewall GUI Access
Grogu
To access Meraki Firewall Device, you have to got to the meraki.com web site? Or can you bring up the Meraki GUI via Public WAN IP? If yes, what would be the port to use, ex. https://x.x.x.x:8080/meraki/ etc. Or does this need to be enabled via xxxx.meraki.com dashboard?  Appreciate the feedback.
KarstenI
You are probably talking about the local status page. Access to it can be controlled from the dashboard:
https://documentation.meraki.com/General_Administration/Tools_and_Troubleshooting/Using_the_Cisco_Me...
Be aware that this status page is only for initial setup for the cloud connectivity and not to configure the whole device. That is only done on the dashboard.
1 Reply 1
KarstenI
