MX65W Can I configure Splash Page for mac-address control?
HI I would like to know if is possible configure a Splash Page for use on MX65W, with same options from MR?
In fact the customer have one MX65W and Ineed configure a MAC-address block with Splash Pash, but I don´t have access to equipment for confirm this and The documentation talk about this kind of configuration only on MR.
Douglas Pereira
Accepted Solutions
Re: MX65W Can I configure Splash Page for mac-address control?
Hi Guys sorry for my delay.
I don´t found any options for use MAC-address filtering, so I created a SSID basic and use a Splash page only and the Customer stay very happy with Splash Page option.
It´s another kind of restrict the Wireless access.
Thanks for your help.
4 REPLIES 4
Some of the dialog here seems to indicate that it may not be possible but it is an old thread and also slightly different.  https://community.meraki.com/t5/Security-SD-WAN/MX65W-access-control-with-meraki-authentication-when...
I tried to dig through some of my devices to verify but seems I don't have any 64W or 65W's to check.  Do you have the device added to a dashboard where you can look through the settings?
Hello Adam, thanks for your answer, I saw this post and my case is different.
I have only one MX65W and I don´t know is one specific feature is present, I know configure on MR,but I need know if have on MX65W, before go to customer.
I don't think in MX65W can give you the things you want.
Below is the screen shot of access control in MX65W.
I deploy this to a small office with 1-5 users only.
I hope below screen shot can help you to understand what best to choose for your customer.
/Tony
Access ControlAccess Control
Splash PageSplash Page
Wireless SettingsWireless Settings
Access Control - Click throughAccess Control - Click throughAccess control - 3rd PartyAccess control - 3rd PartyAccess Control - RADIUSAccess Control - RADIUSAccess Control - Facebook LoginAccess Control - Facebook Login
