MX64 Warm Spare configuration
Dave443
 I am in the process of trying to setup a Meraki MX64 warm spare.. Here are the issues I am faced with
This is in a larger office building, There are 2 ISPs being used a Primary and Secondary WAN, ISP A is Fiber and they just ran a ethernet handoff to the server room. ISP B is the Cable provider and there is a modem with Multiple Ethernet ports on it.
I previously have attempted to set this up as follows
ISP A     Only has the ethernet handoff so I obtained a Dumb switch basically to act as a Hub, the connection for ISP A goes into the switch and then out to the 2 Meraki's
ISP B Has multple ports on the device and I have a Ethernet from Each to each Meraki
Port 1 on each device is then connected to the LAN Switch.
 This works, however, once the this is in place the overall bandwidth for the network slow to basically a crawl as far as speed goes? Where am I going wrong?
2 Replies 2
DarrenOC
Are your MXs configured for HA and running VRRP between the two?
Have you tested each WAN/ISP connection separately to rule out an upstream issue with each.
And finally are you load balancing over each WAN connection or using WAN 1 as primary and WAN 2 as secondary
Bruce
Couple of thoughts.
  1. The MX64 will only do 200Mbps if you’ve got all the threat protection switched on - although I wouldn’t call that a crawl.
  2. Will your ISP A (fibre) provide you with multiple IP addresses? Maybe they only allow a single address and it is jumping between the HA MXs. Both MXs need to have IP addresses (and you have an option to have a third, VIP, if you want to).
