This is a test environment before I try it on the customers production MX64.
I have 2 Internet feeds. WAN1 is configured with one Internet provider and Port 4/WAN2 is configure with another Internet provider. I want all traffic to go out WAN1 unless it's destination is a certain IP address. I cannot seem to get this to work.
You are talking about internet traffic outside the vpn?
Wan1 is primary? And load balancing disabled?
Can you share your rule? And how did you verify its not working?
WAN1 is primary, LB is disabled. I want all traffic going out WAN1 unless it's destination is
Tracert is not a valid test, is based on ICMP, Look at this information:
Note: ICMP traffic is not subject to traffic shaping rules. As a result, Flow Preference will have no impact on ICMP traffic.
So if WAN1 is defined as the primary uplink tracert will go for WAN1. You can change your primary uplink for WAN 2.
Wan2 is a mpls? 10.x is not a internet address.
Or is it a destination in your autovpn?
But, just an observation, It's a rule for Internet traffic, for VPN you should have to create an SD-WAN policy:
