MX64 Down/ Upload Speed
ebrger
hi,
I need your help with the following:
I have a MX64, so far I have had 50M down and 50M upload with my provider.
There was a system change to 200M download and 200M upload.
If I do a speed test, I also get about 200M download, but unfortunately still 50M upload.
Under SD-Wan I have adjusted the speeds.
Am I missing something?
Many thanks Eric
If you plug a device directly in the internet modem/router you get 200 up?
ebrger
Thanks for your help.
Unfortunately, it is currently not possible for me, as this is a remote site. I can only check something on site next weekend.
The ISP is also informed.
But these values can already reach the MX64?
Check the uplink configuration is set to the max (you'll have different numbers to the ones shown below).
Security & SD-WAN / SD-WAN & Traffic Shaping
ebrger
Hi PhilippDAth,
That's right, it's on Maximun. In this case 250M.
I don't quite understand why download works and upload doesn't.
Can anyone confirm that the MX series can technically have the same upload as download?
I want to exclude that the MX can only upload 50M and download 250M!?
Unfortunately I am still waiting for feedback from the ISP.
