We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 27.
Is there a converter available that can be used on the fiber WAN ports of a MX250? Ports are SFP+ fiber but inet cabling is RJ45. I know there is one available via Cisco, but it only references use on LAN ports.
Thank you.
Solved! Go to solution.
@THodgesOSC : You can use that on the WAN port as well
https://community.meraki.com/t5/Security-SD-WAN/MX250-WAN-Port-SPF-Compatibility/td-p/10300
No need for a converter, just use MA-SFP-1GB-TX or a compatible SFP.
It was my understanding that the MA-SFP-1GB-TX only works in the LAN ports and not the WAN ports. Is that not the case?
It works in any SFP or SFP+ port. It makes no difference if it is a LAN or WAN port.
