- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Bug: Refreshing Umbrella API Key in Meraki MX84 is not possible
Hey,
i just implemented Umbrella in our MX84 and MX64W Setup.
Due to not writing down the secret of the API key, i had to refresh the key in Umbrella.
Now my MX64W is working perfectly. But after removing Umbrella protection in MX84 dashboard I'm not able to reactivate. I did not ask me the new credentials.
It's just saying:
There were errors in contacting Cisco Umbrella:
- Umbrella API Error. Code: 401. Error: Invalid authentication credentials
Does anyone know how to remote the stored keys?
Thanks in advance
Joachim
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Umbrella API is configured on a per netwowrk basis.
Just go to "Network -> General" within your MX84 protected network, delete the API credential (on the bottom of the page) and you should be good to go setting it up using the correct key..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks a lot!
It seems like I had been blind all the time.
Completely removing the account under the general tab solved my problem.
