@Adam with my laptop I can reach the .1 but I can't get any further than that.
IP configuration on the MX it's uplink is the same as it was in the laptop
The MX is online with WAN2, but I always configure this through the local page in case it goes offline.
@PhilipDAth Ok, this is exactly what I thought.. I'll get back in touch with the provider to figure this out.
His quick Google skills made him email me to use 1:1 nat..
I'm not sure if they are willing to change their /31 into a /30.
This is a ping from the provider his side towards the MX250. Pings are responding and OK
But the other way arround it does not work.
1921_rtr1_access_AJD#ping vrf VO-ISP 192.168.99.1
Type escape sequence to abort.
Sending 5, 100-byte ICMP Echos to 192.168.99.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
c1921_rtr1_access_AJD#ping vrf VO-ISP 192.168.99.2
Sending 5, 100-byte ICMP Echos to 192.168.99.2, timeout is 2 seconds:
c1921_rtr1_access_AJD#sh arp vrf VO-ISP
Protocol Address Age (min) Hardware Addr Type Interface
Internet 192.168.99.1 - 881d.fc17.9da1 ARPA GigabitEthernet0/1
Internet 192.168.99.2 0 e0cb.bc07.8c72 ARPA GigabitEthernet0/1
