MX250 H.A. + OSPF NX5K
Tim_Patrick_ADS
We have two Nexus 5K's with HSRP between them connected to a pair of MX250's using One Arm running MX14.39 code.
NX5K1-SW1
Interface 1/1
 description MX250-1
 switchport access vlan 1000
vlan 100
 ip address 10.10.10.1/29
 ip route ospf 100 area 0.0.0.0
 hsrp 100
   preempt
  priority 110
  ip 10.10.10.3
NX5K1-SW2
Interface 1/1
 description MX250-2
vlan 100
 ip address 10.10.10.2/29
 hsrp 100
  priority 110
  ip 10.10.10.3
MX250-1
Internet Interface
IP address 10.10.10.4/29
VRRP 10.10.10.6
Gateway 10.10.10.3
MX250-2
Internet Interface
IP address 10.10.10.5/29
VRRP 10.10.10.6
Gateway 10.10.10.3
OSPF Settings
Router ID 10.10.10.6
Area ID 0
Cost 1
Hello 10
Dead 50
MD5 auth Disabled
Yet On NX5K-SW1 I have a flood that does not appear to stop of the following OSPF errors.
OSPF-4-Auth_ERR: ospf-100 received a packet from 10.10.10.2 on vlan 100 with bad authentication 2
On NX5K-SW2 I have the following errors
OSPF-4-Auth_ERR: ospf-100 received a packet from 10.10.10.1 on vlan 100 with bad authentication 0
OSPF-4-Auth_ERR: ospf-100 received a packet from 10.10.10.4 on vlan 100 with bad authentication 0
I have had a TAC case open and it's gone nowhere so I wanted to see if anyone else has this working correctly.
3 REPLIES 3
ps. Are you only running OSPF?  If you are also running BGP you could consider going the BGP Beta and BGP peering with the MX250 instead.  The BGP has been around for a while in MX so should be pretty solid.
Unfortunately only OSPF right now, I used the BGP at my last environment and had good luck with it but this place has complications preventing us from easily moving to BGP.
Tim_Patrick_ADS
I think I figured the issue out, on NX5K2 the global ospf statement has digest turned on this is forcing switch 2 to expect an MD5 auth. We are working with our data center team to resolve the issue.
Switch 1
router ospf 100
  router-id 10.10.7.40
  redistribute static route-map static-ospf-redist
Switch 2
router ospf 100
  router-id 10.10.7.41
  area 0.0.0.0 authentication message-digest
