MX250: A power supply is offline
AbrahamMunoz
A connected power supply is offline
 Slot 1: powering
 Slot 2: connected
What are the recommended troubleshooting steps for this? Couldn't get much out of Meraki Docs, which I usually refer to.
Cool dudes use Cisco Meraki (⌐■_■)
Zedilt
The connected status means that the power supply is connected in the chassis, but not powered.
Probably forgot to connect a power cable to the second PSU, or its not fully attached, or not plugged in at the other end, or you got a faulty cable.
Adam
I just checked one of mine to see if that is normal.  Mine both show as powering on a MS350-48.  Depending if this is in production you could try turning the switch off and reseating both power supplies or swapping them into each others slots to see what happens.  Then power back on.
I checked on an MS425 and they were both in the state "powering" - same as @Adam.
So perhaps "connected" is not normal.  I think I would be tempted to open a case with support.  I think I would also be tempted to remove and re-apply power to the power supply that reports as being "connected".
Zedilt
AbrahamMunoz
At the end power source was the issue, so it was connected but not powered on.
