MX250 - 802.1X Auth
RaphaelL
MX250 - 802.1X Auth
 Hi ,
Does anyone know if MX250 / 450 ( on any firmware versions ) are supporting 802.1X / Hybrid Auth ?
I don't see the option on the adressing and vlans page. It might be restricted in the backend.
Thanks ,
RaphaelL
Confirmed by Meraki : Unfortunately at this time only the MX64/65(W), MX67/68(C/W), and Z3 models of security appliance support 802.1X auth on the local LAN ports
7 Replies 7
Inderdeep
RaphaelL
Yes , we already have hybrid auth on our MX64, 65 , 68 .
This page lists these devices : MX64/65(W) and MX67/68(C/W) and Security Appliances, as well as Z3(C) but not the 250 and 450.  I would be surprised to learn that it is not supported since the cheap hardware on a MX64 can do it.
Mx 64 65 etc are devices also directly serving user/client devices.
Mx85 and up are more likely to sit in mer just doing routing/sdwan.  With some switches connected to it.
Inderdeep
No document around if it is there in MX250 !
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
CptnCrnch
8021.x is restricted to the smaller, more "office" oriented MX series like MX64, Z3 etc.
RaphaelL
Inderdeep
Yeah that was what Meraki put the document around with MX64/65(W), MX67/68(C/W), and Z3 models only.
