Search instead for
MX100 update to MX 13.33
Good Morning.
Since this update was pushed out on Apr, 7th. Has any had any issues with their Security device since this rollout?
I elected to hold off on updating our firmware till I received data from others that had.
9 REPLIES 9
Re: MX100 update to MX 13.33
13.33 is the Stable Release Candidate so it isn't full release yet.  But I haven't tested so perhaps some others can chime in.  I know some folks going to later firmwares were having appliance reboot issues.
Thank you Adam for your response.  I've have recently taken over the role here and found that our MX 100 has not been firmware updated for sometime.
The 13.33 was the only version showing that I needed to apply.  But from what I read here, yo do not see any possible issues with us updating to this?
What firmware version is your MX currently at?  13.28 is the current stable version.
Adam,
I show our Security Appliance is at MX 12.22
And when you go to upgrade it, it doesn't give you 13.28 as an option?  Just 13.33?
Only the 13.33. No others were offered when I set up the schedule.
Strange, but I wouldn't worry to much about it.  The stable release candidate 13.33 is basically a stable release so you should be fine.  If you click the firmware number in the dashboard it'll show the release notes. This article spells out some of it.
https://documentation.meraki.com/zGeneral_Administration/Firmware_Upgrades/Meraki_Firmware_Release_P...
Thank you Adam. That was also one of the documents I had looked at. You have been very helpful sir. I will then allow this update to roll out as scheduled.
I've used 13.33 on a bunch of devices without issue.
