Hey anybody.
General Description:
I have a customer having issues with Auto VPN due to the fact that the MX changed the UPlink IP address.
Detailed Description:
In the scenario we have a MX working as a VPN concentrator behind a 3rd party vendor FW (FW-A).
The MX has two Uplinks to FW-A onto WAN1 (10.10.1.2) and WAN2 (20.20.1.1).
On FW-A there is a NAT rule for the IP of WAN1 to be transformed into a specific public IP Address.
For WAN2 there is no specific NAT rule.
In the past I think it is almost one year in the past it was planned to set up the MX as a warm spare cluster. And for a short period of time there was a 2nd MX. Therefor a warm spare was configured and a virtual IP (10.10.1.1) was set. So the NAT rule on FW-A was changed to reflect this setting. SNAT 10.10.1.1 to public IP.
Once the 2nd MX was put of the cluster, nobody reversed thechange and the MX continued to work with its virtual IP. Now after a longer period of time it changed his interpretation of the Cluster Situation and uses his WAN1 IP address for uplink communication. This causes the NAt rule not to match and results in a failure for the VPN.
To solve the VPN issue we have changed the NAT rule, works.
❓ Question:
But I like to know,
- why was the change of the "warm spare cluster situation" now? (The MX was able to hold its virtual IP live for such a long time without seeing the spare partner for months)
- Is there a known Timer behind it?
- Is there any kind of notification that should appear?
- does anybody know if this is recognizable in any kind of logging?
