The scenario I'm thinking of is as follows:
Central Data Centre site with two MX84s in HA Mode. Remote site with a single MX67. Internet access at both sites (of course!). I want to support three VLANs on the remote site, Data, Voice and Wi-Fi, and I plan to run Split-Tunnel VPN  from the remote site to the Data Centre.
I know I can set up VLANs on the remote site, with a local SVI. I know I can set up VLANs on the central site, but my question is: "How do I set the MXs up so that the VLAN ID/traffic etc, is retained across the VPN?", so for example, the Data VLAN traffic created on the remote site emerges over a trunk port, in the right VLAN in the Data Centre.
I've Googled to no avail....there are suggestions that this should work but I can't find hard facts.
As a side issue, I believe if I'm going to do this, I can't run the Data Centre MXs in VPN Concentrator mode, but need to use Routed mode, and use two ports, not run the MX one-legged. That seems reasonable because the VPN will come in on one port (native VLAN) and will exit in a VLAN contained in a trunk on another port...is that right?
Any example documents showing how to do what I'm trying to do would be a bonus!
Thanks Guys!
Jim
