- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
MX syslog
Is someone able to tell me exactly how to identify traffic that is hitting specific L3 rules?
Ive defined the local syslog server and added "Security Events" and "Appliance Event Log" to it in Network-wide>General-Reporting
I have ticked the syslog box against the rules I want to see what traffic is matching, yet nothing is getting logged to my syslog server even though the hit counts on those rules is going up.
I am getting other msgs on the syslog server from the MX ok though.
TIA
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
So if you configured flows or firewall as a tag in the syslog server configuration on Network wide -> general then you can indeed tick boxes on your L3/4 rules and when they get hit they will log to the syslog in 3 lines.
A flow start log will be made which shows the normal and translated IP addresses (can't be filtered)
A flow or firewall log that actually shows a logic match at the end so you'll have to think what ports and protocols you are matching in that rule to recognize the matched rule.
examples:
protocol=tcp sport=43958 dport=443 pattern: allow all
protocol=udp sport=54366 dport=53 pattern: Group Policy Allow
I don't have access to our logging server to show better examples right now.
A flow end log after the connection is terminated with also the NAT information like the flow start.
We log several firewalls like this and haven't had any issues with that.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Probably Your syslog server is misconfigured.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Nope, its not filtering anything, displays all the other events, just nothing from the L3 rules where I ticked the syslog box
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Check the documentation. It's very simple to configure.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You need to send "flows" to syslog
And you need to select the syslog checkbox behind the firewall rule
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
That then sends absolutely everything, not just the rules where I tick the syslog box - I only want to see what is hitting the rules I have ticked the syslog box on.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thats not possible.
You get the flow and hits. Or nothing
You would need to filter on the syslog server itself
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I get the flows but I dont see any hits arriving on the syslog server for the rules I have ticked.
Unless there are just so many i cant see them, Is there anything specific you are aware of in the text that I can filter by?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Which syslog server are you using?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
visual syslog
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Maybe it will help you.
https://youtu.be/3wdYaI2D4Ow?t=159
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
examples:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thats great, many thanks.
It sends every flow to the syslog server rather than just the ones Ive ticked the syslog box for though, but not an issue (other than generating unnecessary traffic), I've just filtered on the syslog server to show those where message contains "deny"
