MX slowing down internet speed by 90 %
braham2019
Recently I found that 'local' internet access is rather slow. When I run various speed tests (wireless or wired), it gives very bad results.
This is my (simple home) setup:
ISP = MX64 == Switch 1 == Switch 2
            AP1           AP2          AP3   AP4
I have an MX64 with direct WAN connection as firewall, and then two Cisco switches as LAN switches. There's a Gbit uplink from switch 1 to MX via "Trunk port". The second switch is uplinked to switch 1 via Etherchannel (2x Gbit). All cabling is CAT5e. All MR are visible on the switches with Gbit speed.
I have MR33, MR18 and MR76 access points. They all run the latest firmware for the specific model.
I did some speed tests:
- directly plugged into the ISP modem: 295 Mbps (maximum configured in modem is 300 Mbps)
- from a computer located in switch 2 to a computer in switch 1, I get Gbit speed (940/975 Mbps)
- from a wireless client connected to AP4 or AP1 to the internet: 40 Mbps
- from a computer located in switch 1, switch 2 or the MX to the internet: 30 Mbps
When I run a Dashboard Throughput test from any MR, I get 15 Mbps. When I run the same test from the MX, I get 260 or 280 Mbps.
It seems to me the MX is slowing down internet traffic seriously. I didn't have this before (say last week) and I wonder it this is due to a recent update ? I am running the beta version MX 18.103 at the moment.
Any thoughts ?
Does it make sense to revert to (older) stable firmware ?
braham2019
I guess I solved my own problem. I changed firmware from beta to stable RC MX 17.10.2 and the issue is gone.
2 Replies 2
braham2019
BlakeRichardson
Awesome thanks for sharing, I was going to suggest traffic shaping. The MR18 is very old so you might want to think about replacing that at some stage.
