MX port numbering in dashboard / Addressing & VLANs page
joopv
On a template based MX68 based organisation, the / Addressing & VLANs page of the template, the numbering starts with Port 2.
Can someone tell me if this port 2 is actually the first LAN port (next to the 2 Internet/WAN ports) ?  Or is port 2 really the second WAN port?
It will depend, but if I'm correct it's the port number 3.
BlakeRichardson
Ports 1 and 2 are WAN ports and 3-10 are LAN.
If you look at the client page and add the port column, you will see for many MXs that the port shown is indeed N+1.  Therefore port 2 is the labelled port 3 as @alemabrahao stated.  Try on your network and this will confirm it for you, but it is definitely the case for an MX75.
