MX in L2 Transparent mode with Client VPN
Hi guys,
I have implemented a client VPN with no issues when the MX is in NAT mode but due to Meraki not supporting IPTV multicast I have decided to use the MX in passthrough mode and now since doing so I have lost my client VPN
Is this feature available if so do i just need to route vpn traffic to the MX from my ISP router
Any advice appreciated
12 REPLIES 12
Kind of a big deal ww
Re: MX in L2 Transparent mode with Client VPN
what do you mean with lost my client VPN?
I can no longer connect from externally into my LAN via the CLient VPN
I can no longer connect from externally into my LAN via the Client VPN
L2VPN no longer responds, my thoughts are that I may need to forward to the MX internal IP but again im not 100% sure on this
any errors in the log? you have nat upstream and forwarded the vpn ports to the mx ip?
Hi @ww
thanks that's my basic setup I have not changed any settings yet on the ISP router thats what I was thinking if I had to setup port forwarding to the meraki on 192.168.0.13
Yeah you'll need to forward VPN traffic (UDP ports 500 and 4500) to the MX.
https://documentation.meraki.com/MX-Z/Client_VPN/Troubleshooting_Client_VPN#Other_Problems
You'll also need to add a route on the default gateway for the client VPN pool via the MX.
Are you suggesting that I add routes into the default ISP router ?
If so this may be another stumbling block 😞
My router has only very basic options
If you can't add a route to the ISP router, then you would need to add it to the devices that you need remote VPN access to (hopefully a server or PC ...).
All sorted thanks so much guys
It was the routing from the ISP router that was causing the errors
